p100 code
Old Nov 15, 2012 | 03:19 PM
bryan307's Avatar
Default p100 code
can anyone help,recently brought 2.5 crd 2002 within 2 weeks turbo blew had it replaced but now its started to smoke quite bad,not using and oil and runs well,had the egr off and cleaned then blanked off tried to get the ecu read but cannt read anything with 3 machines not sure what to do as chrysler want £100 to plug in,doing the key test its showing p100
does anybody know anyone with in staffordshire area how doesnt charge the earth and is recommended
Old Nov 16, 2012 | 03:50 AM
joker2cv's Avatar
P100 should be a code related to the MAF sensor.
Old Nov 16, 2012 | 12:12 PM
bryan307's Avatar
i have unplugged the maf sensor and it makes NO difference at all is this right?
Old Nov 16, 2012 | 02:38 PM
Default Code p100
Hi Bryan307,
If you have unplugged the MAF sensor you are now running on the (tps) throttle position sensor that gives you help to get home on reduced load....But sometimes reduced load as it might be running better due to MAF sending crap signals to ECU...
Try a second hand one to make sure...
Goggs...
Old Nov 16, 2012 | 02:53 PM
bryan307's Avatar
ok would that cause all the smoking as well?
sorry for sounding so dense lol
Old Nov 17, 2012 | 03:31 AM
joker2cv's Avatar
Mine CRD 2.8 doesn't light up the MIL light if i disconnect the MAF (strange)...
The fact that you havn't difference if you disconnect the MAF, could means that your MAF is broken.
Try to buy a new one in Ebay with about 35 €.
Old Nov 18, 2012 | 02:30 PM
bryan307's Avatar
looked on ebay they are around £250
Old Nov 19, 2012 | 03:38 AM
joker2cv's Avatar
Old Nov 19, 2012 | 03:32 PM
bryan307's Avatar
ok thanks will order one today do you think this will stop my car smoking?
Old Nov 19, 2012 | 03:42 PM
Default MAF air mass meter...
All I can say is Interesting that its possible to get this part at that price on E-Bay.
Goggs.
