Passenger Door Panel
Old Mar 20, 2010 | 04:37 PM
hannadock's Avatar
Cool Passenger Door Panel
I have a 99 TC and need a diagram of the passenger door. I need to take the panel off and don't want to break my clips.
I have taken all the screws off but can't get it off. The bottom is loosened but the sides are really tight and I don't want to scratch up my door. Thanks
Old Aug 8, 2010 | 03:25 PM
Marine531 AutoTech's Avatar
Getting the door off my 2001 was a bit tricky. I could do it now in a few minutes. Took 3 screws out (door handle, bottom, door pulling cup).
Started popping the door loose all the way around the door.
Detached all the electrical connectors, (pull out the red slider (position assurance lock) half way out on the big green connector then disconnect the big green connector)
then removed the plastic attachment to the mechanical door latch by rotating the plastic part 90° off the metal rod.
Old Aug 8, 2010 | 08:23 PM
99 and 01 not the same door panel
the 99 has 2 hidden by carpet screws on the front half there will be hols there U can feel them and some carpet is covering them up
also a screw behind the switch part that panel comes off.
parrym
Jun 27, 2011 02:02 PM
rastoma
Mar 17, 2011 10:29 AM
vcandrk
Mar 12, 2009 11:34 AM
Newtoo300s
Jun 2, 2008 01:56 PM
mperez738
Jul 28, 2007 02:39 PM
