PCM Embossed Number
Old Aug 24, 2020 | 10:55 AM
Earl D's Avatar
Default PCM Embossed Number
Just received a reman PCM. There are three rows of number embossed on the PCM casing of both the old and reman PCM. The rows of numbers are stacked on top of each other. The top two rows of numbers are exactly the same. The third row, on the old PCM which I removed from my van, is the numbers 12. The reman PCM which I just received in the mail for the third row is the numbers 10.
I put the reman PCM in and the engine still would not start. I called the company that I bought the PCM from and they said the numbers 12 vs 10 doesn't matter.
Does anyone know if the numbers being different have any significance? I have read a few threads before where a security system comes into play. My van does not have a security system.
Thanks for any feedback.
Old Aug 24, 2020 | 06:52 PM
The numbers are likely for there use when programming. As long you gave them the right info then should be good to go.
Old Aug 25, 2020 | 10:22 AM
Earl D's Avatar
FYI, all I gave them was the VIN number and verified that they had the correct number. When I received the PCM and realized the last two numbers weren't the same, I questioned them and they said it didn't matter.
Since the van would not start, I had a mobile mechanic whom I know look at the van. He got no "fire" from the new PCM but did get "fire" from the old PCM. His opinion is that they did not program/flash the PCM correctly.
I called the reman company this morning and they said they'd process a refund. I mailed the PCM back to them 15 min. ago. I doubt they refund my entire - if any - money. We shall see.
Thanks for the feedback.
stuuupid1
9
Mar 27, 2015 11:32 AM
dstevens49
Aug 27, 2014 07:57 AM
clhs
Mar 15, 2011 08:06 PM
ETD66SS
Jan 29, 2007 10:39 AM
shelby
Dec 8, 2006 02:24 AM
