po171 bank 1 lean
OBD-II DTC: P0171 System Too Lean (Bank 1)
Keep in mind you have a MAP sensor. They speak of a MAF sensor but your MAP sensor serves the same purpose only goes about it in a slightly different way.
why chrysler are picky what they use can you tell the correct ones the use
the long fuel trim was 23% becouse i also changed the injector
it maid a big deference from 23% from 00%
i used ntk and denso o2s
