po171 bank 1 lean
Old Dec 10, 2012 | 04:11 PM
97 plymouth's Avatar
Post po171 bank 1 lean
hellow i have 97 plymouth voyager with 3.3 2wd
i replaced both o2s i keep getting this po171
could it be the wireing or other it does not stall
Old Dec 10, 2012 | 05:49 PM
FIREM's Avatar
What brand sensors did you use?
Chryslers are known to not like sensors other than OEM or NGK. If you used Bosch that will be a problem.
Old Dec 10, 2012 | 06:11 PM
Raptor 07's Avatar
OBD-II DTC: P0171 System Too Lean (Bank 1)
Keep in mind you have a MAP sensor. They speak of a MAF sensor but your MAP sensor serves the same purpose only goes about it in a slightly different way.
Old Dec 10, 2012 | 09:43 PM
i think ntk denso
why are chrysler are picky
maybe you can tell the ones they realy ues it would help thank you
Old Dec 10, 2012 | 09:46 PM
Default fuel sys lean bank 1
i think its ntk and denso
why chrysler are picky what they use can you tell the correct ones the use
Old Dec 11, 2012 | 06:30 AM
Question po171 bank one lean
ntk and denso thoes are the o2s i uesd
Old Dec 16, 2012 | 04:34 PM
Default po171 bank one lean
hello i changed one of the o2 s now one of upstrim is now workong
the long fuel trim was 23% becouse i also changed the injector
it maid a big deference from 23% from 00%
i used ntk and denso o2s
Old Dec 16, 2012 | 04:35 PM
firsttime
Other
Dec 26, 2011 11:05 PM
dlamora
Jun 10, 2011 07:34 AM
nithawk2000
Jun 20, 2010 06:13 PM
pdcab
Jul 5, 2008 05:59 PM
96RedLXI
Aug 18, 2007 09:36 AM
