Power Sliding door maintence and Power seat issue
Old Jun 21, 2016 | 11:44 AM
Mikey Z's Avatar
Default Power Sliding door maintence and Power seat issue
Hi Guys just bought a 2012 TC one of the power doors is a little noisy. Sounds like the top bushing/roller. Whats a good grease for this????
Also the power seat stopped working, I am taking it back to the dealer for the fix as its covered but is this something to look out for in the future??
Old Jun 29, 2016 | 07:50 AM
andyb2000's Avatar
Hi Mikey,
Welcome to the GV club, you've got one of the newer models there so hopefully you'll enjoy!
The rear power doors, a general/light grease should be fine on the rollers for that, just make sure you wipe excess off so it doesn't gather and drop onto the bodywork at some point. They are a little noisy since they're always exposed to the elements.
Hopefully you've had the seat sorted by now, do you mind posting back what they did (If they told you?). I'm going to guess something simple like a faulty connector under the seat that supplies it with power. It's no more a common issue than most electrical faults, anything that moves and has cables or connectors will fail over time.
As always, please do post back when you get a solution or progress for others to see and know how you solved it.
Old Jun 29, 2016 | 11:56 AM
Mikey Z's Avatar
The power lumbar harness some how how got chewed up and was causing the short. Dealer replaced the switch which has the harness attached. All is working.
Thank you
dakrt360a
Oct 4, 2013 11:32 AM
Huslayer
Jan 28, 2013 10:14 AM
bugsbunny16374
Jul 13, 2011 06:41 AM
Gunther_bluez_mo_difficult
Jul 20, 2010 12:16 PM
Gindyhead
Nov 12, 2008 11:13 AM
