Power Steering Problem
Old Jan 26, 2007 | 02:43 PM
Elisha's Avatar
Default Power Steering Problem
After letting my power steering fluid level to go low,I lost power steering. After refilling with genuine fluid and "burping" the system I am still having intermittent loss of power steering. Other symptoms are a high pitch sound emanating from the belt (I think) which is glazed. I cannot see a leak as the pump is buried so low under the engine. It was suggested that the cause may be a hose leak, internal leak, pump failure or rack & pinion failure.
given my symptoms, which is it?
Old Jan 26, 2007 | 03:03 PM
Default RE: Power Steering Problem
yeah ne number of them can be the prob haft to have some one look at it for a leak if u have low fluid then u have a leak some where have some one look at it and tell u whats goin on the noise can be 1 of 2 things or both the belt tensioner is a common thing to go bad and a PS pump will make that sorta noise.
Old Jan 26, 2007 | 03:29 PM
Elisha's Avatar
Thanks Chrysler Tech,
I have replaced the tensioner along with the belt about a year ago when this noise first appeared, The noise then stopped.2 months ago the noise came back . The power steering problem is new, 3 days ago.
Old Jan 26, 2007 | 03:54 PM
shnormo's Avatar
while the engine is running, have some one turn the wheel and add fluid... sometimes this will help trapped air come out.
Old Jan 26, 2007 | 06:34 PM
u will know if there is air the amber color fluid will be light amber milky .
no air and no visable leaks pump has taken a crap.
Victor L
Jan 12, 2014 08:38 AM
04_sebring
Dec 19, 2011 10:32 AM
bassy
Aug 28, 2011 12:16 PM
Gumby
13
Feb 19, 2008 08:59 PM
allenl44
Sep 16, 2006 12:21 PM
