Radiator Fan Dead
Old Jan 18, 2024 | 11:01 AM
woodthumb's Avatar
Default Radiator Fan Dead
on my 06 3.8 the rad fan suddenly stopped working last week.... condenser fan works as it should... are both fans on one relay ? do u think that one fan could be bad ? does not overheat but gauge does climb to halfway at idle...used to never get to halfway so thats when i checked ...letting van idle for 20 minutes condenser fan worked as should...temp gauge went to halfway and stayed there, but radiator fan never kicked on... thanks
Old Jan 19, 2024 | 08:33 AM
user 7698720832's Avatar
. Mine's a 2.8CRD but believe the fan circuits are similar, three relays controlling two fans ! oops - slightly different diagram attached from manual (don't trust the manual too much !). check if you have voltage across the fan
Old Jan 20, 2024 | 04:48 AM
woodthumb's Avatar
ok so after diggin into this yesterday i took a chance on one fan being bad and one relay controlling both... seems i was right... installed new dual fans and both work...albeit VERY loud... and......but......a/c condenser fan turns opposite rad fan thereby blowing air out instead of pulling it in... weird... back to advance today and a redo.. thanks for input
Old Jan 21, 2024 | 03:50 PM
just reverse wires on a/c fan - motor will go opposite way ! (careful of shorts !!)
Old Jan 23, 2024 | 08:46 AM
woodthumb's Avatar
yep... u r correct but i swapped out for another complete assy anyway and all good now... both pulling air in as should and this new one is MUCH quieter... first was wired wrong from factory as each fan is supposed to spin opposite for some reason thus the reason the blade pitch on each are different.... weird but ok now....thanks
Old Jan 23, 2024 | 12:45 PM
Glad to hear everything now sorted - well done... interesting about the fans' rptation.
Silentdub2
Jul 2, 2018 07:57 AM
celamantia
Jul 7, 2014 09:25 AM
Cheg
Jun 18, 2013 11:51 PM
ulyman
Aug 7, 2009 09:18 PM
colbertgang
Apr 26, 2009 09:30 PM
