Instrument cluster gauges and indications malfunctions
Old Jan 23, 2024 | 12:50 AM
Znn's Avatar
Znn
Default Instrument cluster gauges and indications malfunctions
Hi
Voyager 2000 3.3 A/T
Gauges (heat,tacho and fuel) ,indications like odometer ,selector position PRND all of them are not working properly, the engine starts normally but these gauges not work unless when turning the key switch to start while the engine is running they work for few seconds then drop again.
Alarm set ,ABS and Break indications lamps are lit
Any advices are appreciated 👍
Old Jan 23, 2024 | 01:06 AM
Znn's Avatar
Znn
Old Jan 23, 2024 | 01:00 PM
When the gauges are not working smack the top of the dash . This is a common issue with the printed circuit board in the cluster the solder points break There are people online that see ones they have resoldered or you can try it yourself.
agravitt
Jan 8, 2016 11:15 PM
13walkec
Jan 13, 2014 04:31 PM
Michael T
Oct 5, 2013 06:15 AM
dwstoick
Mar 16, 2013 12:13 AM
thomascathybell
Jan 18, 2011 05:09 PM
