radio volume
Old Jul 10, 2016 | 02:57 PM
rw64's Avatar
Default radio volume
hi a mate as brought a 55 plate voyager but the radio as no volume at all
put another radio in still no volume off any controls on radio or steering wheel do not get the volume number on the radio when you use the controls
any ideas would help
Old Jul 11, 2016 | 09:36 AM
My916's Avatar
I believe there is an amplifier in the rear right quarter panel. Maybe that's bust or isn't getting power. Probably worth a check.
Old Jul 12, 2016 | 07:22 AM
andyb2000's Avatar
Hi,
This could be a number of things, there are many posts on the radio and amplifier setup in the Voyagers from your age (same as mine), and yes it sounds like the amplifier isn't turning on.
First check your fuses, always the simple things first and see what you can find.
Also, you need to provide more details. UK or USA spec, model, factory fit radio/head unit or aftermarket?
Generally they need to have factory fit head units in as these send a coded signal over the CANBUS network to signal to the amplifier to turn on, etc.
You mention the steering wheel controls don't change volume, that's interesting and makes the wiring on the head unit suspect too.
post back with more details and we'll see what we can figure out.
Old Jul 21, 2016 | 09:35 AM
rw64's Avatar
hi uk voyager factory fit were is the fuse for the amp as above no volume number on radio
Old Jul 21, 2016 | 09:57 AM
andyb2000's Avatar
OK, the fuse is part of the IOD if memory serves me correctly!
See the image below for where it's located:
BUT, if you're saying when you turn the volume control and it doesn't show on the screen the volume level numbers, that's a bigger issue and may point to the radio itself being faulty. Does it switch channels, turn on and off, accept CDs, change tracks, etc, just no sound?
Old Jul 21, 2016 | 10:08 AM
rw64's Avatar
yes turns on and off cds yes channels yes tracks yes this the same both radios
thanks diagram this will help a lot
pregis100
Mar 11, 2014 03:46 AM
robertaz45
Mar 14, 2013 10:01 AM
kschestnut
Aug 21, 2008 01:29 PM
bradybun
Oct 13, 2005 07:18 PM
builtfspd2
Jul 8, 2005 09:05 PM
