Rear blower smoke
Old Jan 16, 2018 | 10:35 AM
DCMoose48's Avatar
Default Rear blower smoke
'99 T&C... during the summer I turned on the rear blower for the air conditioning once and when I parked there was smoke (not steam) coming from the driver's side rear wheel well. I've used both the a/c and heat with only the front blower on since then with no problem. I rarely drive the van but I might have to start using it regularly soon so I'd like to see what I can do about this problem. Any advice is greatly appreciated.
Old Jan 16, 2018 | 01:30 PM
REBEL59's Avatar
As the rear heat/a/c and blower is a self contained unit. Remove the Interior trim panel on that side and INVESTIGATE. The blower motor may have bitten the dust, but you will definitely know once you can see the whole unit. But where are you located, as ALL rear units I have seen and driven the unit is in the Passenger (Right Rear) rear corner.
Old Jan 18, 2018 | 09:31 AM
DCMoose48's Avatar
Thinking about it now I think it was the passenger side... I've found a couple videos showing access so I will look into it once the weather warms up. Do you know how difficult it is to actually replace the blower motor? I'm not a mechanic but I can do repairs that aren't extremely complex. Would the Haynes book help with this?
Old Jan 18, 2018 | 09:50 AM
REBEL59's Avatar
While it is not near as good as a factory service manual(for all you purists),It does give good basic instructions for most common things the average DIYer can do..So yes, it would be helpful.
Biggest job is to remove the interior trim panel for access, from there it is simple couple of bolts to remove the blower motor and fan. A replacement most likely will come with new "squirrel cage" fan.
Once you get the trim panel off you will be more than able to see what is going on and what it will take to repair it.
carid
Aug 12, 2015 06:11 AM
Chiefgrunt
Jul 7, 2013 05:15 PM
shuby70
Sep 24, 2011 03:42 AM
fielderosa
Sep 28, 2006 10:52 AM
maximum123
Mar 14, 2006 12:04 AM
