Voyager Headlights not working
Old Aug 3, 2011 | 06:51 PM
cshannon's Avatar
Smile Voyager Headlights not working
Hi All,
i have a 2004 Voyager chrysler. Today I discovered the headlights were not working. First thought was fuse. Could not find a fuse for them.
did some research on here and internet and some people have said that when the headlights fail, the washer pump fails as well. Thats is not the case for me. Everything is working bar the headlights. Full beam is ok.
I could only find one fuse box and that is the one under the bonnet (hood).
Any sugestions as to where i might be able to find a fuse or realy for the headlights please.
Many thanks
Old Aug 4, 2011 | 06:24 AM
ettienne's Avatar
Blown light bulbs?
Old Aug 4, 2011 | 09:56 AM
cshannon's Avatar
Originally Posted by ettienne
Blown light bulbs?
Thanks for replying. I tried that, although it would have neem unlikley that 2 bulbs would blow at the same time. Thanks
Old Aug 4, 2011 | 02:07 PM
SheppeyTrio's Avatar
Have you checked the relays in the fusebox under the bonnet???
There's another fusebox under the cover under the steering wheel area!!
Old Aug 4, 2011 | 04:21 PM
cshannon's Avatar
hi, thanks for your reply. I looked for the realy which would control the lights, but couldn't find one. I also thought there was another fuse box inside, but alas, there isn't on this model. When i tried to get some info from a Chrysler service centre, they said there is no fuse for the lights nor a relay. I find that strange unless I am living in the past.
Thanks anyway
Old Aug 10, 2011 | 02:53 AM
sjbilton's Avatar
Are the wires into the connector on the back of the bulbs intact? Our melted the dipped connector so the lights failed - I bought a VW T4 loom off ebay and replaced the wiring - there's another thread about this somewhere on here...
Old Jan 18, 2018 | 12:06 AM
ymohamed@randmutual.co.za's Avatar
Default Both Head Lamps Low Beam not working
Hi, I'm experiencing the same problem as you. How did you eventually resolve this iss
Originally Posted by cshannon
Hi All,
Many thanks
Old Jan 18, 2018 | 10:44 AM
dieselvoyager's Avatar
The front module connector can go bad , it's on the front end of the fusebox.
blueflareon
Nov 9, 2013 07:54 PM
Brenda Elizondo
Apr 13, 2013 02:01 PM
oldirtydpg
Jan 28, 2011 08:44 PM
rastoma
Jul 7, 2009 07:41 PM
sl00py99
Oct 22, 2008 07:03 PM
