Rear vents on 2014 T&C not blowing any air
Old Jul 26, 2023 | 09:26 AM
wscsuperfan's Avatar
Default Rear vents on 2014 T&C not blowing any air
I have a 2014 T&C. Recently I noticed the no air comes out of the rear roof vents. The front and rear controls work. I can hear the rear blower motor running and it responds to controls. I went ahead and replaced the rear blower motor, but it has not fixed the problem. What else could be causing this?
Old Aug 2, 2023 | 04:55 AM
VMdiesel's Avatar
I guess you checked the fuse before replacing the fan, right? Is the fan spinning (making noise)? You could probably easily measure if it gets 12 V when it is supposed to blow at max RPM.
Old Aug 25, 2023 | 10:43 PM
rhensonsr's Avatar
I just replaced my rear evaporator and it was so clogged that I am surprised anything was going through it. Now my rear vents blow stronger. Good luck.
adamgx03
Aug 9, 2020 04:26 PM
xr500
Jul 21, 2019 11:30 AM
Xpress
Jun 19, 2018 06:47 PM
BARCLAY
May 19, 2010 04:57 PM
RobNordic
Sep 14, 2009 07:40 PM
