Rear washer not working on 1996
Old Nov 27, 2005 | 02:10 PM
b350m's Avatar
Default Rear washer not working on 1996
I have a 96 T& C and the rear washer quit working. I see that there are two pumps on the reservoir. How do I know which to change and how do I change the bad washer pump?
Frustrated,
Bob
Old Nov 27, 2005 | 02:17 PM
oldchina's Avatar
Default RE: Rear washer not working on 1996
I had a '96 once with the same problem. Crawl under the pass. fender and touch the pumps while someone is pushing the front washer so you'll know which is which. To replace the pump make sure the reservoir is empty first, because once you remove the pump, it'll pour out. Or roll up your sleeve and put a pan under the pump area. Make sure you have the new pump on hand. The old pump just pulls out of a rubber friction fit grommet. Twist while pulling. Disconnect the plug. That's it. Reverse the procedure to install. Hopefully it works. If not check your body control module. I had a shorted diode in mine once and the pump wouldn't shut off. I had to unplug it.
Old Dec 1, 2005 | 09:31 PM
b350m's Avatar
Thanks for the reply. I bought a new pump and put it in. I thought I had all the fluid out of the reservoir but I didnt , got quite a bat but at least it works. Thanks for the advice.
yadog
Jan 5, 2014 04:48 PM
hotcharity95
Nov 29, 2011 08:56 AM
3.3lxbluevan
9
Dec 10, 2010 07:17 PM
sapper7697
Jan 27, 2010 03:15 PM
LT102
Dec 29, 2006 02:52 PM
