Sponsored by:
Sponsored by:
Resetting change oil notification on 2012 T&C
Old 03-03-2012, 03:43 PM
Charles.b.poole's Avatar
Default Resetting change oil notification on 2012 T&C
Trying to reset change oil notification on 2012 Town and Country. 2011 and below techniques aren't working.
Old 03-06-2012, 01:43 PM
ChryslerCares's Avatar
Your vehicle is equipped with an engine oil change indicator system. The CHAngE OIL message will flash in the instrument cluster odometer for approximately 12 seconds, after a single chime has sounded, to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle-based, which means the engine oil change interval may fluctuate dependent upon your personal driving style.
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the STEP button on the steering wheel. To reset the oil change indicator system (after performing the scheduled maintenance), perform the following steps.
**Vehicles Not Equipped With Keyless Enter-N-Go**
1. Turn the ignition switch to the ON/RUN position (do not start the engine).
2. Fully depress the accelerator pedal, slowly, three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you start the engine, the oil change indicator system did not reset. If necessary, repeat these steps.
**Vehicles Equipped With Keyless Enter-N-Go**
1. Without pressing the brake pedal, push the ENGINE START/STOP button and cycle the ignition to the ON/RUN position (Do not start the engine.)
3. Without pressing the brake pedal, push the ENGINE START/STOP button once to return the ignition to the OFF/LOCK position.
johnpvb
02-24-2014 01:48 PM
cdysthe
06-30-2013 10:52 PM
chipsstuff
04-18-2010 05:55 PM
tejasaspen
01-16-2009 10:38 AM
judlicht
06-24-2008 04:39 PM
Quick Reply: Resetting change oil notification on 2012 T&C
