Rough ridin
Old Feb 18, 2016 | 05:39 AM
woodthumb's Avatar
Default Rough ridin
hey guys... bought this van new and taken really good care of it.. notice it is beginning to ride rougher than usual , even with new tires ( same as always ).. could the shocks be worn at 140000 ? and.. is there 4 shocks and what is difference in shock/strut ? thanks
Old Feb 18, 2016 | 11:39 AM
rw64's Avatar
yes there are four shocks two front and two rear the fronts are called struts or shocks hope this helps
Old Feb 18, 2016 | 01:41 PM
What do you mean by rough riding. Is there knocking or bumping noises from below. Or is it wandering on the road.
Old Feb 19, 2016 | 02:41 PM
woodthumb's Avatar
no noises... rides rougher than when new... like on a ground up highway before the re-paving... like to make it new again... shocks ?
Old Feb 20, 2016 | 02:19 PM
Do the shock test. Press down on each corner (if you can) let it go and it should rise with no bounce. Does steering turn easily with no binding as per top mount seizure. Try fitting front wheels on back and vice versa as this cures or finds faults.
larry664
Aug 27, 2016 02:46 PM
tlc3152
12
Sep 28, 2007 12:06 AM
dnation
Apr 5, 2007 02:50 AM
OTWOLIMITED
Jan 30, 2007 11:43 PM
idahoborn399
Dec 15, 2005 05:37 AM
