Rough working
Old Sep 21, 2012 | 06:12 PM
nelpasa's Avatar
Default Rough working
My 2002 TC 3.3Lengines functions smoothly while in neutral, but when I engage the transmission and while standing runs very rough. When running at normal speed it runs smoothly.
Old Sep 22, 2012 | 12:49 AM
any codes in the computer?
Old Sep 22, 2012 | 11:35 AM
nelpasa's Avatar
Default rough working
code is 0305.-I have replaced: the crankshaft sensor, spark plug, injector, fuel pump, throttle control sensor, map sensor. Could it be that the ECU needs flashing?
Old Sep 22, 2012 | 05:05 PM
the 305 is a number 5 misfire a crank,TPS,map sensor has nothing to do with that code nore does a fuel pump u replace the plugs but not the wires? what about the coil pack?
Did u look up what the code means b4 u spent all the money and time on the above things?
Old Sep 24, 2012 | 03:09 PM
Raptor 07's Avatar
Are you getting consistent spark and fuel injector pulse, when in gear? If yes then check compression.
http://www.obd-codes.com/p0305
Old Sep 25, 2012 | 05:34 AM
nelpasa's Avatar
I just did a valve job
larry664
Aug 27, 2016 02:46 PM
tlc3152
12
Sep 28, 2007 12:06 AM
dnation
Apr 5, 2007 02:50 AM
OTWOLIMITED
Jan 30, 2007 11:43 PM
idahoborn399
Dec 15, 2005 05:37 AM
