Sliding Door
Old Apr 12, 2014 | 06:41 PM
davidgossett's Avatar
Default Sliding Door
Hi all, I have a passenger sliding door that drags metal to metal at the top at the sliding hinge . The door you can lift up and it has movement about 1 inch or so. the other door does not have this. Is this a adjustment issue or is something wore out? Thanks for the help.
David
Old Apr 13, 2014 | 03:54 PM
If you have 1 inch free play I'm sure you have a roller away or roller/track come loose. Check one door against the other looking for any parts/track not the same. Think you'll be on your own on this one on here as sliding door adjustments are a dealer trained tech job....If you can find one that is...
Old Apr 13, 2014 | 03:55 PM
Oh and report/picture back any outcome please.
Old Apr 13, 2014 | 05:39 PM
The whole removal and replacement
including the top hinge
Old Apr 14, 2014 | 07:28 AM
You Tube right enough, have found some interesting stuff on there. Should always be checked for repairs on there.
Old Apr 14, 2014 | 08:08 AM
Thanks for the info. I will look there too. Thanks again David
dakrt360a
Oct 4, 2013 11:32 AM
Huslayer
Jan 28, 2013 10:14 AM
cajunlady2
Sep 24, 2007 11:18 PM
gregngina
Sep 28, 2006 12:01 PM
stokes
Feb 19, 2006 10:29 AM
