Small Oil Leak
Old Aug 14, 2018 | 05:17 AM
Taronga76's Avatar
Default Small Oil Leak
Hi all,
I am looking for some help, I have a slight oil leak from the screw circled in red, can anybody tell me what the thing is called in the red square, I assume it's to do with the oil but need to find the actual name, I assume that a gasket has gone and will need replacing, I have tried tightening the screw/nut and that made no difference.
This is a 3.3 v6 Chrysler Grand Voyager UK (Town and Country).
Thank-you
Old Aug 14, 2018 | 11:43 AM
Taronga76's Avatar
So I found out it's the rocker cover/valve cover. I have checked the screw again and since tightening it, the leak appears to have stopped. When I first checked, I'm wandering if it was still a little bit of oil left I had not cleaned up properly making me think the leak was still there. I will keep an eye on it, but the gaskets are fairly easy to change over and quite cheap luckily.
Tris1
Jun 1, 2017 07:26 PM
mrorange
Mar 11, 2016 09:20 AM
finnennis
Feb 19, 2009 05:17 PM
Hightechman89
Cirrus & Breeze
Mar 26, 2007 11:12 PM
jason1
Nov 9, 2006 05:28 PM
