oil leak
Old Nov 1, 2006 | 08:17 PM
jason1's Avatar
Default oil leak
hi guys does anyone know if there is a common place for the voyager 2.0 to leak oil from ive changed the rocker cover gasket but it still seems to be leaking its getting quite bad now as the oil is all over the back of the engine and gearbox
thanks Jason
Old Nov 2, 2006 | 03:56 PM
webbee's Avatar
Default RE: oil leak
Get one of those mirrors on an extension rod. From underneath, run the mirror along the parts you can't see easily from underneath. Same along the top from the front of the van. Leaks are sometimes difficult to locate. It also could be a stripped/under tightened bolt allowing the gasket to leak despite replacement.
Another method is to add an ultra violet dye pack to the oil. run it for 10 or so miles and then use a UV light to spot the source of the leak.
Sensors sometimes blow the interior seal and leak but these usually are easy to find/spot.
As always, good luck with your project!
Old Nov 2, 2006 | 04:57 PM
jason1's Avatar
thanks for the advice mate but i got it on to a ramp to day and the back of the engine and gear box are covered in oil looks like it needs a good steam clean before i will be able to see where its leaking from do you know of any common places where they might leak from.
Jason
Old Nov 9, 2006 | 05:28 PM
jason1's Avatar
think ive found it
it seems to be leaking from the camshaft seal above the gear box
jason
milesy_boy
11
Nov 19, 2009 05:34 PM
garr5859
Aug 21, 2007 11:51 PM
Hightechman89
Cirrus & Breeze
Mar 26, 2007 11:12 PM
Hightechman89
Cirrus & Breeze
Mar 25, 2007 05:59 PM
Cat
Mar 1, 2006 08:25 PM
