So Many problems! PLs help!
Ok I have 4 things going on with my Town and Country.
1. When the gas gets down to about a quarter of a tank, the car has trouble taking off when I press the gas and sometimes feels like it's going to stop going while I'm driving.
2.Banging noise under my feet on drivers side. I can feel it, and it only does it when I let off gas, not when I press it.
3. Squeeking noise coming from front passenger tire area.
4. A wooshing sound from front passenger tire area that comes and goes.
Thanks for any help!
-Cindy
-Cindy
Model year?
1. If it is indeed fine above a quarter tank I would suspect the pickup tube on the pump has shifted or is being blocked somehow or the tank is contaminated by something. Only way to find out is to drop the tank and pull the pump. It's mounted in the top of the tank.
Bang, squeak and a woosh. I'll second Chrysler Cares statement. I can only take a stab in the dark.
2. Strut mount, sway bar or A frame bushing, inbaord cv joint. You're going to have to have someone take a look.
3 Ditto
4. Is it associated with running the A/C? Sometimes low refrigerant will produce what's been described as a woosh sound under the dash.
3 Ditto
stinkytofus
Oct 7, 2013 09:57 PM
ukfan33
Apr 13, 2012 08:29 AM
DJBowens
Apr 26, 2011 05:44 PM
