Some gauges not working (fuel, oil, temp) ?
Old Jan 20, 2012 | 12:45 PM
stuffpilot's Avatar
Default Some gauges not working (fuel, oil, temp) ?
On my 95 Town & Country the fuel gauge, oil pressure gauge and the temperature gauge are not displaying anything on the digital dash. The the interminent wiper function and rear hatch release are not working either. I noticed that there is a small star or dot character flashing on the dash too. The battery gauge and speedometer seem work just fine. The fuse for the gauges seems to be good. A mechanic friend of mine found a black plastic connector under the dash by the fuse panel disconnected but I am wondering if it is some type of test hook up. It has two rows of flat spade connections. Any help or ideas would be appreciated.
Old Jan 21, 2012 | 01:52 PM
stuffpilot's Avatar
Is there a relay that controls these specific items?
Old Sep 11, 2012 | 03:07 PM
Augie's Avatar
My 95 Town & Country is doing the same thing. Did you ever figure it out? I need any help I can get. Thanks
Old Sep 12, 2012 | 06:03 PM
stuffpilot's Avatar
Yes, the bad part was the Body Control Module. It is located beneath and behind the lowest center console. I bought a used one off of ebay. They are hard to find in the right specs. I don't think Chrysler makes them anymore. I paid like $80 on ebay and it works and has done well. If my old information is correct I think the Hollander # is 591-3210 and the Chrysler part # is 4686732 which is what I found on ebay. Hope you fix it and good luck. Let me know if I can help further.
Old Sep 12, 2012 | 06:09 PM
stuffpilot's Avatar
Also, if you have a good contact at a Chrysler dealer in parts and give them your VIN and tell them it is a body control module they may be able to give you other part numbers that will work too!
dormant75
Sep 15, 2011 08:12 AM
bodgieoz7@bigpond.com.au
Apr 13, 2011 10:03 AM
Gadbot
Oct 31, 2010 03:27 PM
d3aglewhor3
May 5, 2009 12:58 AM
zil130
Jan 17, 2009 07:44 PM
