Starts fine then dies when moving
Old Apr 19, 2015 | 09:29 AM
Nudge's Avatar
Question Starts fine then dies when moving
2002 T&C, starts and idles fine. When we put in gear (drive or reverse) it dies. Then we can restart and it drives fine the rest of the day. This only happens when it has been sitting a long time, such as over night. However, I've let it sit until mid-day and it does it so it doesn't appear to be temp or humidity related. The remainder of the day it drives without issue and we can restart 8-10 times during the day without issue, then the next day we restart, no matter how long it idles, it cuts out when you first start to move and apply the gas. When you restart, it often doesn't happen again and I've never had to restart more than twice. Again, it runs fine other than this issue.
I've replaced the fuel filter and I put a pressure gauge on the fuel rail. The pressure is within specs. I also watched the gauge as my wife backed the vehicle up and it died, but the fuel pressure didn't drop out.
It is now showing a O2 Sensor code per Advance, but in reading other post, those can be misleading, so I wanted input before I just start throwing money at the problem.
Thanks for your help,
Nudge
Old Apr 19, 2015 | 02:52 PM
You say Gas so are you Petrol.
Gringo Starr
Aug 12, 2016 07:37 PM
aaron1wii
Aug 26, 2014 01:05 PM
stpetesebring2000
Mar 1, 2013 01:55 PM
nates90
Dec 12, 2012 07:17 AM
DJ_Playing
Apr 22, 2006 03:58 PM
