Steering Vibration 2005 T&C
Old Dec 19, 2018 | 11:53 AM
PositiveMojo's Avatar
Default Steering Vibration 2005 T&C
Vehicle: 2005 Town & Country.
Problem: Vibration in steering wheel while stopped. The vibration increases when I turn the steering wheel left or right. The vibration varies in intensity from day to day, sometimes minute to minute.
Steps taken: Replaced the power steering pump with new (not rebuilt) Cardone, replaced PS reservoir, added new PS cooler kit from Hayward Automotive, changed ATF-4 fluid so the system is spotless.
The only thing I haven't replaced is the power steering rack (steering gear). My trusted mechanic friend told me not to do it because he didn't think that was the problem.
Has anyone had this problem and fixed it? What did you do?
Old Dec 19, 2018 | 01:25 PM
BiliTheAxe's Avatar
It could be bad motor mounts.
Have you had someone hold the brakes on with it is in gear and the hood up to see how the engine reacts?
If the engine shakes a lot more, it would not be any of the things that you previously tried, but a bad motor mount could.
Also, run some seafoam or lucas fuel system cleaner through the car, it could simply be dirt in the engine, causing the engine to vibrate more while in gear.
Old Dec 20, 2018 | 12:26 PM
That's what I thought too but I had the dealer check the motor mounts and they are fine. The engine is spotless. When you take off the serpentine belt there is no vibration. It's definitely coming from the steering system.
ken52479
Sep 24, 2012 04:13 PM
oea
Jul 8, 2009 09:31 PM
chryslervan
Mar 21, 2009 10:07 PM
Jon87transam
Aug 4, 2007 09:00 PM
CurtisZ
Jan 5, 2007 03:31 AM
