T&C 2010 Side doors won't open/close
Old May 18, 2015 | 02:27 PM
Waggy's Avatar
Default T&C 2010 Side doors won't open/close
My 2010 Town & Country's back side doors has just decided to stop working when you press the button on either back post. I have no problem opening/closing either door remotely or with the button over the dash. I tried changing the switch on the doors that suppose to shild proof the door and no change. Any ideas? I can not believe it is the switch as both stopped at the same time.
Old May 19, 2015 | 09:28 AM
ChryslerCares's Avatar
Hi Waggy,
There was a Technical Service Bulletin released to address the issue with the power sliding doors not responding to the buttons. This TSB involves removing the sliding door trim panel and modifying the foam around the handle on the right and/or left side. I’ve included more information on the TSB below for your reference. Please let me know if you would like assistance in scheduling an appointment with your local dealership. I would be happy to help!
TSB NUMBER: 23-005-10
GROUP: Body
DATE: March 02, 2010
SUBJECT: Power Sliding Door Will Not Power Open
OVERVIEW: This involves removing the sliding door trim panel and modifying the foam isolator around the handle link on the right and/or left side.
MODELS: 2009 - 2010 (RT) Town & Country/Grand Caravan
NOTE: This bulletin applies to vehicles built before February 12, 2010 (MDH0212XX).
SYMPTOM/CONDITION: The customer may experience that the power sliding door on the right and/or left side not
opening when using the interior or exterior handles or interior B-pillar button from full closed position but works with remote keyless entry and the front row overhead console buttons.
NOTE: The sliding door will power close and properly function in all manual operations.
DIAGNOSIS: This procedure only address vehicles that do not power open using the interior and exterior handles or interior B-pillar button from full closed position. This does not address any closing issues.
Old May 20, 2015 | 07:02 PM
georgef's Avatar
Check the "Power Sliding Door Master Switch" on the overhead console.
From the 2010 manual:
To provide a safer environment for small children riding
in the rear seats, the second row power sliding door
switches may be overridden by pressing the OFF side of the Master Lock
Out Switch located in the front overhead console to the
ON position.
The newer model manuals state it more clearly:
When the power sliding door master lock switch is in the
OFF position, the power sliding side door may not be
opened or closed by pressing the switch located on the
b-pillar trim panel, just in front of the sliding door...
George
Old Aug 12, 2024 | 07:22 AM
Alasco's Avatar
Originally Posted by ChryslerCares
Hi Waggy,
GROUP: Body
Hia.. just found this reply online (in August 2024) and wondered if this TSB 23-005-10 from 2010 still existed and if the procedure could still be done as the rear doors have just stopped working exactly as described here on my Chrysler Grand Voyager LTD CRD A here in the UK. Any info I can give my local garage would be a great help. Thanks.
RCrosby
Sep 16, 2014 06:57 AM
tipopilota
Jan 11, 2014 05:44 PM
Jersey Mike
Mar 1, 2013 03:34 AM
jostclan
May 4, 2011 01:55 PM
firebiz16
Feb 6, 2006 06:30 PM
