Terrible noise
Old Aug 7, 2015 | 07:42 AM
HarleyRob's Avatar
Default Terrible noise
I have a 2008 TC that is making a terrible hum when crusing down the road. The faster you go the louder it gets. And is worse if you turn to the right at all. Cud it be the tires? Tires are worn out and due tob replaced. Ive checked PS fluid. Steering seems fine. There is no hum when idle. Only when moving. The noise is very annoying!
Old Aug 7, 2015 | 10:18 AM
Vmaxxer's Avatar
Wheel bearings?
Old Aug 7, 2015 | 10:22 AM
HarleyRob's Avatar
Is there a way to check the wheel bearings myself? I'll search the forum but any help is appreciated.
Old Aug 7, 2015 | 11:06 AM
HarleyRob's Avatar
OK, after researching wheel bearings it seems this is the problem. Do I understand correctly that if you turn the wheel while driving and the noise goes away then it is the OPPOSITE wheel bearing? So, if I turn left and it goes away (doesn't really go away entirely) it is the right wheel bearing?
Old Aug 7, 2015 | 02:24 PM
Jack up each wheel, spin it and listen...
Old Aug 10, 2015 | 01:38 PM
HarleyRob's Avatar
Default still confused
OK, jacked up the front end and spun both tires. Nothing sounds out of the norm. So, I'm having trouble deciding which hub is bad. If I follow a curve to the right the hum increases. Does this mean the driver side hub is bad? If I straighten back up or follow curve to left there is no increase in sound.
Old Aug 10, 2015 | 03:02 PM
If turning right on a curve and it sounds noisier, its the left wheel, as the load is increasing on that wheel due to car wanting to go straight on. Think of the scenario where the right wheels would lift off the road if you were going really fast around a sharp bend to the right. Good for doing roll overs right enough into a ditch.
Old Aug 10, 2015 | 03:04 PM
HarleyRob's Avatar
Makes sense! That's exactly what it is doing! Thanks. Just waiting for the new wheel bearing to arrive.
Old Aug 11, 2015 | 02:22 PM
Is it a hub with bearing as that's what's for sale on Fle-bay. Be interesting to know if there quality or copies from China.
Old Aug 11, 2015 | 02:38 PM
Front hub bearing units on Fle-bay for £33 odds, one seller Jeep-Chrysler too. Not worth the bother of removing the bearings and pressing in new.
Mad-MF
Jan 13, 2011 04:34 PM
davidmendelson
Jun 20, 2009 09:44 AM
race
Jun 12, 2009 09:29 PM
Aquinas
Apr 18, 2007 01:59 AM
toplessone
Mar 29, 2006 10:10 PM
