Tow electrics?
Old Mar 12, 2011 | 09:44 AM
voyager_dan's Avatar
Default Tow electrics?
hi does anyone know if a 2002 crd grand voyager is can bus wiring?
do i need an extra electrical box to divert the wires through or is it possible just to tap into the existing loom?
cheers
dan
Old Mar 12, 2011 | 01:07 PM
griffo's Avatar
Hi Dan,
I have a 2003 cdr Voyager and when I had my electics fitted for towing the auto electrician tapped into the existing electics.
He said the only thing he could not do was wire up the fog light as this would cause a fault in the system.
I have been running this for over two years without a problem.
Cheers
Mark.
Old Mar 12, 2011 | 02:00 PM
can bus did not come out until 04 and was not standard until 08
Old Mar 13, 2011 | 05:58 PM
cheers guys, i have electrics already fitted to the car when i brought it
when towing the caravan i noticed when the sidelights were on the fog light on the caravan was also on
so i thought that it may be can bus as i know it can cause issues when tapping into the wiring
the other issue is that the o/s indicator is working but the buzzer doesnt seem to work on this side
i will disconnect the fog lamp wire and see what happens
anyone have an idea why having the fog lamp wired up causes problems
dan
dale_hopkinson
Aug 20, 2014 03:19 PM
williams1958
Dec 21, 2011 06:49 PM
simonbliss
Nov 22, 2010 12:15 PM
MikeF
Jun 10, 2010 09:20 AM
gaz440
Jan 6, 2010 01:10 PM
