town & country 2001 xe
Old Feb 23, 2009 | 11:55 PM
otel800's Avatar
Default town & country 2001 xe
Hi. i was wondering if any could help me ..... i recently changed my battery an i have noticed this red light turn on by dash it looks like a small red dot ..... ??? what is it and how do i get rid of it.
Old Feb 24, 2009 | 10:00 PM
ghlkal's Avatar
Where on the dash is this indicator light?
Old Feb 25, 2009 | 07:49 AM
otel800's Avatar
it is located were the turn signals are located and were the oil light is located
Old Feb 25, 2009 | 11:04 AM
actd's Avatar
I'm still fairly new to this stuff (in which case, someone more experienced may know better), but I think it may be the check engine light, in which case take a look at this:
http://www.allpar.com/fix/codes.html
and scroll down to the section on resetting codes. Please let us know if this does it.
Old Feb 25, 2009 | 03:30 PM
Merlin's Avatar
Sounds like the VTSS light (alarm) is this the light that flashes when the alarm is on? It could have just got spiked it is normally on after a battery change but goes out as soon as you turn the ignition on and the indicators flash to confirm set up. could try disconnecting the battery again and let it all power down for 5 minutes then reconnect if not it has a fault.
Old Feb 25, 2009 | 04:17 PM
actd's Avatar
Talking
Yep, they do :-)
Old Feb 25, 2009 | 07:57 PM
ghlkal's Avatar
Yes, the "red dot" is the factory alarm ... flashes when it's being armed IIRC.
Old Feb 26, 2009 | 08:37 AM
otel800's Avatar
thankyou you all for you help i will try battery diconnect and let you know the out come !!!
Old Mar 3, 2009 | 08:08 PM
otel800's Avatar
tryed battery and got nothing
Old Mar 4, 2009 | 07:40 AM
Merlin's Avatar
checked the fuses?
