Town & Country gauge inaccuracy
Old Oct 20, 2014 | 04:20 AM
Ericbo101's Avatar
Default Town & Country gauge inaccuracy
For the past few months, every time I add gas after reaching empty (light on), I am having to add more. I am now reaching over 19 gallons while fueling just after the light on. So I am guessing my gauge is drifting
How can I check the gauge accuracy ? (electronic scanner ?)
What is the most likely fault and part to replace ?
Appreciated !
Old Oct 20, 2014 | 05:19 AM
Leedsman's Avatar
More important than your question is what's in your tank that shouldn't be there? You don't say what your vehicle is exactly, but I can tell you if water gets in diesel it goes straight to the bottom of the tank. This is so important some makers fit water traps in the fuel system.
You should check all this out immediate otherwise you could get a pintle blown off an injector due to high-pressure steam -- result? Lots of £££/$$$ out of your bank account.
Leedsman.
Old Oct 20, 2014 | 08:28 PM
Raptor 07's Avatar
This instrument cluster test is US spec but would suspect it will work for you if you have anything older than a 2008.
DIAGNOSIS AND TESTING - SELF-DIAGNOSTICS
The instrument clusters are equipped with a self diagnostic test feature to help identify electronic problems. Prior to any test, perform the Self-Diagnostic Test. The self diagnostic system displays instrument cluster stored fault codes in the odometer display, sweeps the gauges to the calibration points, and bulb checks the warning indicators. When the key is in the ON position with the engine not running, the MIL will remain illuminated for regulatory purposes.
To activate the Self-Diagnostic program:
With the ignition switch in the OFF position, depress the TRIP ODOMETER RESET button.
Continue to hold the TRIP ODOMETER RESET button until Sof and a number (software version number (i.e. Sof 3.2) appears in the odometer window then release the button. If a fault code is present, the cluster will display it in the odometer display. When all fault codes have been displayed, the cluster will display “end” in the odometer display. Refer to the INSTRUMENT CLUSTER DTC'S table to determine what each trouble code means. INSTRUMENT CLUSTER DTC'S DTC DESCRIPTION
100.0 LOOP-BACK FAILURE
100.1 ABS COMMUNICATION FAULT
100.2 BCM COMMUNICATION FAULT
100.3 EATX COMMUNICATION FAULT
100.4 FCM COMMUNICATION FAULT
100.5 ORC COMMUNICATION FAULT
100.6 SBEC/DEC/MCM COMMUNICATION FAULT
200.0 AIRBAG LED SHORT
200.1 AIRBAG LED OPEN
200.2 ABS LED SHORT
200.3 ABS LED OPEN
200.6 EL INVERTER TIME-OUT
200.7 EATX MISMATCH
400.0 EEPROM READ/WRITE FAILURE
400.1 IMPROPER POWER DOWN DETECTED
CALIBRATION TEST
The CLUSTER CALIBRATION table contains the proper calibration points for each gauge. If the gauge pointers are not calibrated, a problem exists in the cluster. If any gauge is out of calibration, replace the cluster.
CLUSTER CALIBRATION SPEEDOMETER CALIBRATION POINT
1 0 MPH (0 KM/H)
2 20 MPH (40 KM/H)
3 60 MPH (100 KM/H)
4 100 MPH (160 KM/H)
TACHOMETER
1 0 RPM
2 1000 RPM
3 3000 RPM
4 6000 RPM
FUEL GAUGE
1 EMPTY
2 1/4 FILLED
3 1/2 FILLED
4 FULL
TEMPERATURE GAUGE
1 COLD
2 1/4
3 3/4
4 HOT
ODOMETER SEGMENT TEST
If a segment in the odometer does not illuminate normally, a problem exists in the display.
ELECTRONIC TRANSMISSION RANGE INDICATOR SEGMENT TEST
If a segment in the transmission range indicator does not illuminate normally, a problem exists in the display.
Old Oct 21, 2014 | 09:30 PM
Ericbo101's Avatar
Default A Town & Country 2003
Leedsman.
Sorry should have said, a Town & Country 2003
Ok will consider the possibility of water though the possibility seems remote to me (we are talking of gallons ..)
Old Oct 21, 2014 | 09:32 PM
Ericbo101's Avatar
Default Thank you !
200.2 ABS LED SHORT
200.3 ABS LED OPEN
200.7 EATX MISMATCH
CALIBRATION TEST
1 0 MPH (0 KM/H)
2 20 MPH (40 KM/H)
3 60 MPH (100 KM/H)
TACHOMETER
1 0 RPM
2 1000 RPM
3 3000 RPM
4 6000 RPM
FUEL GAUGE
1 EMPTY
2 1/4 FILLED
3 1/2 FILLED
4 FULL
TEMPERATURE GAUGE
1 COLD
2 1/4
3 3/4
4 HOT
Much appreciated, will try all of that witin a week or 2 and let you know !
Thank you again
Hawgfan
Jul 18, 2014 11:32 PM
J Wikoff
May 15, 2012 03:44 PM
Stevo
Dec 2, 2011 11:38 PM
mostchillin
May 10, 2011 07:32 PM
running_swift@hotmail.com
Aug 14, 2009 05:35 PM
