Trans cover/fluid
Old Sep 20, 2006 | 09:39 AM
tmp03tnc's Avatar
Default Trans cover/fluid
I have a 2002 Town/Country that has developed a leak around the side or end cover seal of the transmission (faces the drivers side of the van). Two questions: What type of transmission fluid should I be using to top this off? Should this side cover be easy enough to remove, re-gasket, and replace myself? Thanks for any advice.
Old Sep 20, 2006 | 10:07 PM
webbee's Avatar
Default RE: Trans cover/fluid
Your tranny uses ATF+4, which is available at the $tealer or from the box auto parts stores by other makers. DO NOT USE ANYTHING BUT THIS FLUID.
I haven't removed that cover so I can't answer the second question. I think I read a thread that someone had done it, and it was tight, but do-able.
You might check a manual.
Old Sep 21, 2006 | 10:21 AM
tmp03tnc's Avatar
Thanks for the info. I knew there could be problems if I used the wrong fluid, but wasn't totally sure what the right fluid was. Hopefully I can trust the stuff sold at the auto parts stores. I'll research the cover a little more before I try it.
Thanks again.
Old Sep 21, 2006 | 07:24 PM
brandoncrone's Avatar
The side cover is easy, and relatively inexpensive at the dealer. You need a special ATF rtv type sealer to seal the cover to the transmission case. I higly recommend Chrysler sealer as this area is prone to leaks. I wouldn't use the permatex crap sold at the auto parts stores.
aggiejet
Jun 30, 2012 03:22 PM
Joe C
Feb 19, 2012 02:24 PM
parlayjay
Apr 18, 2010 03:28 AM
Pacifica3.82007
Feb 26, 2009 08:16 PM
sumncguy
Jul 24, 2007 09:35 PM
