trans filter?? or flush??
Old Aug 2, 2011 | 05:25 PM
palafoja's Avatar
Default trans filter?? or flush??
I bought my 02 t&c last year with 117K, now 18 months later at 130K I want to service the tranny, I don't know if the previous owner ever serviced it, they had some of the service receipts and it looked like it was up to date with everything, but not sure about the tranny. I'm NOT expierencing any problems and I want to avoid any.
questions are; Pan drop(filter and 5 or 6 quarts)??? or flush(probably a job for the dealer$$$)??
any special things I need to do IF i want to do only the pan drop(i'm aware of the atf4 fluid) OE filter?? is after market filter ok???
Old Aug 2, 2011 | 08:42 PM
Djinn-n-Tonic's Avatar
Aftermarket filter is fine, I believe it takes 5.5 quarts to drop the pan. Chrysler recommends NOT FLUSHING these units...so Save your time and money.
I will tell you one warning However....
Disconnect the battery BEFORE dropping the pan.....It will save you the heartache of the quicklearn procedure....
Old Aug 3, 2011 | 04:38 PM
rodger's Avatar
Post
I found ths useful, I know it doesn't give a concrete answer, but the guy does seem to know what he is talking about.
Hope it helps
A word on transmission service from an expert
Old Aug 3, 2011 | 06:26 PM
ettienne's Avatar
The one thing I regret doing is having my tranny filter and oil replaced - no flush. This was done at 120k, since then multiple tranny problems. Hard shifting, slipping, not holding overdrive etc. Done at dealer with genuine parts and Chrysler ATF+4 or whatever $$$ stuff they used.
Old Aug 21, 2011 | 03:49 PM
palafoja's Avatar
I finally did this, it went easy, it shifts smooth, but I think i'm getting the same problem as above, the overdrive not holding, I only drove it a couple of miles, and also noticed that when braking i feel a little bump when speed goes under 30 mph.
Is this all part of the relearning time? I disconected the battery as I was told to do.
Old Aug 22, 2011 | 11:29 PM
wnpl405's Avatar
its better you get it checked by the dealer i too had faced the same problem but it got is solved with the dealer.
Old Sep 1, 2011 | 09:08 AM
palafoja's Avatar
I'm just guessing, but I think the van was trying to relearn how and when to shift up and/or down as well as when to go in od. It's running great as always now, now issues, it only took her a couple of days
zach92
Feb 9, 2014 07:55 AM
Carlo60
Apr 7, 2011 03:45 PM
dcotter0579
Mar 17, 2011 02:36 PM
parlayjay
Apr 18, 2010 03:28 AM
Pacifica3.82007
Feb 26, 2009 08:16 PM
