transmission
Old Feb 22, 2014 | 04:20 PM
nitehwk's Avatar
Default transmission
can anyone tell me if i can take a 2001 t&c transmission and put it into a 2004?
Old Feb 22, 2014 | 10:42 PM
yes U can
Old Feb 23, 2014 | 03:08 PM
Raptor 07's Avatar
yes U can
2001 has the seperate PCM and TCM. 2004 has the single box NGC replacing the PCM and TCM. I would think there would be some daunting electrical issues to overcome.
Old Feb 24, 2014 | 03:35 AM
Leedsman's Avatar
I suspected there would be control issues here. Microprocessor programs can be different even if the mechanical stuff is identical. Datacoms between processors can also be a different format, different speed. Because manufacturers don't always tell you about minor changes, even the same item, same make model, year etc. cannot be guaranteed to be "swappable". It's very much a 'suck-it-and see' process, which may involve you in hundreds of man-hours work plus a lot of money, with no guarantee of a result at the end. This is why a processor board usually has a "software version number" on it -- this applies universally, not just modern motor vehicles.
So Nighthawk, if your present box is faulty/worn, it might make more sense to fix it if the vehicle is worth it.
Leedsman.
Old Feb 24, 2014 | 02:49 PM
same 41TE trans only difference is the flywheel which u will not remove the NGC is for the Engine cam and crank sensor just happens the TCM is built into it that's all.
Old May 6, 2014 | 11:20 AM
Education 41TE Complete rebuild procedure[s].
farmerbob02
Apr 13, 2011 12:04 AM
