trouble code gearbox A604 chrysler V. 2.8 crd C0015 Relay Output Always Off
Old Dec 28, 2014 | 08:27 PM
claoments's Avatar
Default trouble code gearbox A604 chrysler V. 2.8 crd C0015 Relay Output Always Off
Good Morning
My name is cClaoments
new to the forum and I is not too much or post my topic for someone draws help I French,
I have a problem with the gearbox A604 4 speed Chrysler Voyager 2.8 CRD S4 2006
transmission when the time had led speeds went well up to four, once we remove the foot on the accelerator and the speed is less than the 2 and 3 and we are accelerating the speed of the second block.
Note: The A604 has been repaired completely replace steel and friction disc with overhauld kit (OHK) molded solenoid piston converter block, the restoration of the valve body.
After mounting the gearbox A604, we made the diagnosis (MD802 the altar.
The altar of MD802 we said before diagnosis, information: the transmission is in box!
Error code:
1 * DTCs:
- Error Code: C0015 Relay Output Always Off. (Active)
2 * Trouble code:
- Error code: P29. Missing wheel speed rear left. (Active)
- Error code: P31 missing rear wheel speed right. (Active)
3 * Trouble code:
- Error code: FWD sensor Riser / Out of Range Low (stored)
- Error Code: Charging Voltage / Low Message (stored)
- Error code: sensor before Riser / Out of Range (stored)
- Error code: FWD Riser / Sensor Out of Range (Active).
Our fuse relay center and IPM is written PCM.
he TCM on certain vehicles not written.
and our pcm relay is left just below the large relay
write starter relay.
This pcm relay before there is no power that arrived
we removed all blocks IPM FUSE center of relays, and clean all electrical connectors of the circuit
as PCM below the module conduteur wheel.
connectors blocks solenoid Boitie ECM and electrical outlets.
we redid the mase distribution side, taking mase chassis side rails driver
After instalation battery Volte 12.68.
happened current connector tests against the PCM relay 2 relay oké. (12,67volte)
the speeds of the test vehicle still does not change.
clear the default code
no test vehicle.
diagnosis, even the default code always returns.
ducts open, control files
I believe no files found cut.
The dismantling of ECM connector plugs
there is an issue leaves just inside that melted and went to the connectors on two sheets of ECM
we tried to clean it with a cleaner touch repeatedly
toujour it a kind of school that comes ECM connector plugs
right now we think the problem is with those cards that do not communicate with the ECM and other module and transmission
NB: in diagnostic repeatedly
imposible to intéroger elite ECM MD802 said:
1. Secure the ignition is turned ON
2. Check the cables between the test and vehicle diagnostics
3.Check vehicle Whether the battery is charged
4. Check if the system is confugured for the vehicle
on line 15. 16. PCM block 17 which is below the driver's side go
Lines 15 and 17 shows, pool from 3.9 volts to 3.7vols
what matters is whether the ECM on this voture has a role in the transmission with the other modules, if the current does not fall and ECM station involved to Cole on the connector may be the problem,
and this tester problem is not communicating with the control unit
or when the ECM is off services (hs)
sorry for the bad english
Thank you in advance for your help and compréhenssion.
Best Regards
Old Dec 29, 2014 | 01:36 AM
royal100805's Avatar
As you have a stored charging voltage error code I would start off with checking that the alternator is producing the correct voltage. You mention battery voltage is 12.67v. Is this with the engine running or not?
Old Dec 29, 2014 | 08:05 AM
claoments's Avatar
Hello: royal100805
Thank you for the time you took to read and respond.
Engine running: battery charging voltage is 13.93 volte stabilized engine idling.
With the engine off voltage of the battery is 12.40 volte
the voltage of the battery before was 12,67voltes engine off
and before the charge voltage of the battery with the engine running
idle time had gone up to 14 and some flip
but today it is 13.93 volts with the engine running
in slow motion
I hope I have answered your questions
I saw on another forum that we must control the two lines of the alternator output regulator liason with PCM on pins 20 and 57
but with testing the scheme I've found only concerns Chryslers until 2002 and mine is 2006 and the colors of the lines does not correspond with 2002
I have on my alternator 2 files controller output 1 brown with a white band, is this happening directly to the PCM with the same crayon?
or it goes by another module.
and the other as black with a brown belt
and given that I can not communicate with the ECM ??
thank you
Old Dec 29, 2014 | 08:19 AM
claoments's Avatar
And just I forgot if it can help you help me solve my problem the vehicle has 263000km, so I do not know if the brushes are worn regulators
or when there is one or more diodes of the generator is not working view of the vehicle kilometer
How to test the alternator regulator
or if someone can help me with an electrical testing scheme latest chrysler
view this link
Chrysler tested Nippendenso Charging System, 1989 - 2002) but does it not for chrysler 2006 and more
Interpreting the Test Results (Chrysler Charging System, Late 1980s – Early 1990s) - Randy's Repair Shop
thank you
Old Dec 29, 2014 | 06:14 PM
Ok The alternator sounds good voltage wise. Now I would check power at the transmission control module to makersure you are getting the correct voltages in and out.
Old Dec 30, 2014 | 12:34 AM
claoments's Avatar
You talked about the PCM which is under the driver's side wing ??
Can you tell me how to check the voltage at the output of the PCM with the multimeter,
is what are the lines No. 15, 16, and 17
engine off or engine on ?
Contact on or off ?
TRANSMISSION CONTROL MODULE (DIESEL) - BLACK
CAV CIRCUIT FUNCTION
1 T1 18DG/LB TRS T1 SENSE
3 T3 18DG/DB TRS T3 SENSE
6 K24 20BR/LB CRANKSHAFT POSITION SENSOR SIGNAL NO.2
7 D15 20DG/YL SCI TRANSMIT (TCM)
8 T751 20YL FUSED IGNITION SWITCH OUTPUT (START)
9 T9 18DG/TN OVERDRIVE PRESSURE SWITCH SENSE
10 T10 20DG/LG TORQUE MANAGEMENT REQUEST SENSE
11 F1 18PK/WT FCM OUTPUT (UNLOCK-RUN-START)
12 K23 20BR/OR ACCELERATOR PEDAL POSITION SENSOR SIGNAL NO.2
13 T13 18DG/VT SPEED SENSOR GROUND
14 T14 18DG/BR OUTPUT SPEED SENSOR SIGNAL
Teste ;
15 T15 18YL/BR TRANSMISSION CONTROL RELAY CONTROL ( Contact On not voltage ?? )
16 T16 18YL/OR TRANSMISSION CONTROL RELAY OUTPUT ( Contact on 3,9 voltes )
17 T16 18YL/OR TRANSMISSION CONTROL RELAY OUTPUT ( Contact on 3,8 voltes ).
But I'll redo the test tomorrow
to do I put my multimeter + files on the No 15 and - multimeter on - battery and I repeated this process for the other test files
ignition on
is what testing has been well realized or not ??
19 T19 18YL/DB 2-4 SOLENOID CONTROL
20 T20 18DG/WT L/R SOLENOID CONTROL
41 T41 18DG/GY TRS T41 SENSE
42 T42 18DG/YL TRS T42 SENSE
43 D25 18WT/VT PCI BUS
46 D123 20WT/OR SCI RECIEVE (TCM)
47 T47 18YL/DG 2-4 PRESSURE SWITCH SENSE
50 T50 18YL/TN LOW/REVERSE PRESSURE SWITCH SENSE
51 K900 20DB/DG SENSOR GROUND
52 T52 18DG/WT INPUT SPEED SENSOR SIGNAL
53 Z132 16BK/YL GROUND
54 T54 18DG/OR TRANSMISSION TEMPERATURE SENSOR SIGNAL
56 A104 18YL/RD FUSED B(+)
57 Z133 16BK/LG GROUND
58 N7 20DB/OR VEHICLE SPEED SENSOR SIGNAL
59 T59 18YL/LB UNDERDRIVE SOLENOID CONTROL
60 T60 18YL/GY OVERDRIVE SOLENOID CONTROL
sorry I forgot to tell you:
I had the engine running LED.
orange
but now he is off
thank you
Old Dec 31, 2014 | 03:58 PM
claoments's Avatar
Hello, royal100805.
Just say thank you for everything, for the help you gave me and the time you took to read and answer my questions.
I finally found the lead that was cut,
was the leading No. 16 out of PCM that went EATX relay internal filaments was cut inside and outside the sheath was well full, not possible to see that the file is divided.
After repair of the cable and any other cable removed,
Blanked defects with the suitcase Autel Elite MD802,
speeds normally spend very soft, no default
No disrespect to Chrysler engineer beams are very poorly done inside
all queues are folded ised,
normal they cut withdrawn when the transmission or engine vibration or ground
thank you again
Happy New Year 2015 to all of you and your family in this forum and out
best regards
chris_kucia
Jun 22, 2013 12:59 PM
Le_Baron
Jul 27, 2012 03:53 PM
DaveLowes
Aug 24, 2011 04:38 PM
Le_Baron
Other
Jun 13, 2010 01:32 PM
