Trouble code P0202
Hi all,
My Chrysler Grnd Voyager 3.3L Yr2000 recently jerks while driving. Aftr cecking ,i got d trouble code P0301, i.e Misfiring in Cylinder 1. So, I open up d plenum etc n saw d plug cable no.1 was out.
Since,I've opened up d plenum ,I change all d plug cables,spark plug,plenum gasket,valve cover gaskets and fixed back.
Tday,once I start d engine fires but d jerkyness sound was still there and d engine light appears. Upon checking wit my scan tool,I got P0202 appears n it means Injector#2 Control Circuit(Injctr#2 output driver does not respond properly to the control signal.
So,pls advice as to how shud I repair this.
Tqvm.
Tqvm.
I've opened back d plenum and checked all d injectors and strengthened all d connections,if after fixing up evrything again n d problem still persist,what shud I do. Should I change the injector on cylinder 2 or all d injectors,tq
Alex Eremia
Feb 7, 2015 11:35 PM
