Trouble code P0202
Old Jan 25, 2013 | 09:40 AM
Huggy59's Avatar
Default Trouble code P0202
Hi all,
My Chrysler Grnd Voyager 3.3L Yr2000 recently jerks while driving. Aftr cecking ,i got d trouble code P0301, i.e Misfiring in Cylinder 1. So, I open up d plenum etc n saw d plug cable no.1 was out.
Since,I've opened up d plenum ,I change all d plug cables,spark plug,plenum gasket,valve cover gaskets and fixed back.
Tday,once I start d engine fires but d jerkyness sound was still there and d engine light appears. Upon checking wit my scan tool,I got P0202 appears n it means Injector#2 Control Circuit(Injctr#2 output driver does not respond properly to the control signal.
So,pls advice as to how shud I repair this.
Tqvm.
Old Jan 25, 2013 | 02:26 PM
go back and look at what u took off and make sure u did not pinch a wire to the injector or something.
Old Jan 25, 2013 | 05:57 PM
Huggy59's Avatar
Tanx,will do that.
Old Jan 27, 2013 | 09:27 AM
Huggy59's Avatar
I've opened back d plenum and checked all d injectors and strengthened all d connections,if after fixing up evrything again n d problem still persist,what shud I do. Should I change the injector on cylinder 2 or all d injectors,tq
Alex Eremia
Feb 7, 2015 11:35 PM
Robert Pickering
Dec 1, 2014 09:45 PM
97chryslerconcorde
Jul 14, 2011 11:58 PM
felo72
Jun 17, 2010 06:30 PM
MICHAELP4514
Sep 17, 2008 11:07 AM
