troubleshooting P0455..
Old Nov 4, 2007 | 04:13 PM
jquinones's Avatar
Default troubleshooting P0455..
Guys I have this little problem here. Idid go to Autorone to check Engine light and this P0455 come up.
what should I do?
thanks
Old Feb 25, 2008 | 04:47 PM
jquinones's Avatar
Default RE: troubleshooting P0455..
Is that truth that there is this part that control the air from gas line of the car? because I do have this problem with my van P0455, means something with air leak or vacuum something like that.
Could you guys tell me more about this part?
it is truth that this part could be the problem?
thanks guys
Old Feb 25, 2008 | 09:04 PM
magneticred's Avatar
P0455 is a signal that there is a leak in the emissions system. It could just be a fuel cap that is not on tight. You may have a small crack in a rubber hose in the emissions system.
http://www.obd-codes.com/trouble_cod...cted-large.php
Old Feb 26, 2008 | 04:57 PM
jquinones's Avatar
Its not the cap, I put a new one.
How can I find the right gas line to check any problem?
I have a few pictures from under the car, can you point to me which lines are they?
thanks a lot
Old Oct 11, 2008 | 11:01 AM
jquinones's Avatar
anyone to give me another tip? I need to find any problem on EVAP system .
thanks
Old Oct 14, 2008 | 11:53 PM
leaking rubber lines either up top or near the canister under the van driver side.
Old Oct 15, 2008 | 03:11 PM
JeepAndAVan's Avatar
Remove the airbox under hood and look for plastic tube running horizontal and then having a little piece of 5/16" rubber hose for the transition to vertical. This hose is likely cracked.
Old Nov 10, 2008 | 07:09 PM
jquinones's Avatar
I took a picture from under, can you point the lines?
thanks
[IMG]local://upfiles/4356/762A33F17BFD42268F2D4D6CC33A926A.jpg[/IMG]
chandlerkfc
Oct 10, 2012 06:20 PM
jhoward7414
Feb 7, 2012 07:03 AM
Robs Minivan
Nov 1, 2011 04:42 AM
DigitalGreaseMonkey
Jun 21, 2009 08:37 PM
selewoh
Nov 4, 2007 09:02 PM
