Turn Signal
Old Jul 28, 2011 | 08:26 PM
andyr78's Avatar
Default Turn Signal
Our turn signal seems to be acting weird. When it is pushed to turn the left turn signal on, the right signal will light up and vice versa. Not every time, but it happens. Does this mean I need to replace the entire turn signal switch? Or could there be something else wrong?
Old Jul 29, 2011 | 05:31 PM
andyr78's Avatar
Today it happened less than yesterday, but it still happens. Now sometimes the turn signal will not even turn on.
Old Jul 29, 2011 | 10:09 PM
mopwrd340's Avatar
that is a bad t/s switch mine does the same thing i need to replace it ,
Old Jul 30, 2011 | 03:43 AM
andyr78's Avatar
Thanks. I just wanted to make sure there wasn't something else I should check first before replacing the switch.
Old Aug 8, 2011 | 07:58 PM
andyr78's Avatar
Can anyone let me know what years are compatible with our '07 T&C? I am going to try and find a used switch, but need to know what years I can look for. Got caught in a thunderstorm yesterday and the whole switch decided to quit working. I had to pull over because I couldn't get the wipers on.
Old Aug 9, 2011 | 01:01 PM
ChryslerCares's Avatar
You may verify parts compatibility through your local dealer parts department. They can determine what part number it is that your vehicle needs and then verify what (if any) other models use the same part number
Parts and accessories can also be ordered on-line at the Mopar eStore. You can check to see that part that you need and then check other model years to verify if the same part applies. The Mopar eStore can be found on-line at Mopar Parts - The Official Mopar Parts eStore offered by Chrysler
If you wish you can also speak with a Mopar representative, you can call the eStore Hotline at 1-888-349-2298.
Old Aug 10, 2011 | 10:42 PM
andyr78's Avatar
Thanks for the link to promote your website. But I was looking for the years that were compatible with our 2007 T&C.
swittie
Nov 10, 2020 02:02 PM
GSKI
13
Sep 11, 2007 09:33 AM
alan
Jun 11, 2007 09:27 PM
evo8rcr
Jun 3, 2007 12:46 AM
pinecone
Aug 25, 2005 01:13 AM
