Turn Signal problem,,,PLEASE HELP!!
Old Apr 10, 2017 | 10:00 PM
dana.veen's Avatar
Default Turn Signal problem,,,PLEASE HELP!!
I have a 01 town and country that I just replaced the multifunction switch in because i did not have signals or hazards and guess what,,, I still dont! I have checked all the bulbs, fuses and yes I even replaced the BCM thinking that maybe it was the problem. I cleaned the battery terminals so there is no corrosion on the at all. I am not sure where to start next any help would be great, I just want to mention that all other lights work perfectly fine,
Old Apr 11, 2017 | 11:30 PM
Raptor 07's Avatar
If you have a trailer wire harness remove it. Any maintenance done just prior to this problem popping up?
Old Apr 12, 2017 | 07:13 AM
dana.veen's Avatar
there isn't a trailer wire harness, and yes I had to replace the fuel injector wire harness because all the insulation had melted and the wires became one solid mass of wire causing one the injectors to remain open and that's when the problem started
Old May 2, 2017 | 06:28 PM
T&CBud's Avatar
I once had an issue kinda like this on a T&C. Disconnected negative cable from battery, waited 10 minutes, then reconnected. No problems since. Not saying it will work for you, but might be worth a try.
Old May 2, 2017 | 10:33 PM
dana.veen's Avatar
I will definitely give it a try,, right now I will try anything, thank you for the tip I'll let you know if it works.
Old May 2, 2017 | 10:36 PM
dana.veen's Avatar
also just want to mention that the signal flash on the dash like they are working fine but they are not flashing on the outside of the vehicle and I have replace the relay as well and that did absolutely nothing.
Old May 3, 2017 | 05:39 PM
Raptor 07's Avatar
Hmm. That says this isn't the usual turn signal problem. You've replaced the BCM, the part that makes the circuit flash including the indicators on the message center. You've changed the MF switch, the part that tells the BCM what you want it to do. BTW - What relay did you change? There's no relay in the turn sig circuit. Have you double checked the injector harness? Take a close look at the main disconnect connector between the engine bay and the cabin? You may have inadvertently damaged wiring there. My guess is either something in the circuit is loading it and preventing the "flashing" side of the circuit from working or you have an open wire. What to try?
Might try disconnecting each light assembly one at a time and see what effect it has. Nothing? Try the instrument cluster then the message center. You may have to check wire continuity from the BCM to each light assembly and from the MF switch to the BCM. Need wire diagrams? Send me an email address to send them to in a private message. How? Click Raptor 07 at left.
swittie
Nov 10, 2020 02:02 PM
njmiller
Jul 28, 2012 09:46 PM
njmiller
Jun 7, 2012 03:50 PM
SDumitru
Sep 7, 2008 12:34 AM
pinecone
Aug 25, 2005 01:13 AM
