Under tray fixings
Old Sep 30, 2015 | 12:20 PM
Maxcaddy's Avatar
Default Under tray fixings
Hi, without buying a new under tray and side covers, where can I buy just the plastic inserted fixings for the under tray ?
The 10mm screws that go into the front bumper metal are fine, its just the 4 (3 on the side panels and 1 on the bottom tray) that need replacing. I've checked ebay and searched the net, but so far haven't found them
Any ideas ?
Ta
Old Oct 1, 2015 | 02:22 PM
Are you talking about panel fitting clips/whatever there called, that look like round head plastic bolts with fins instead of threads. I'll see if I can find that box of them that I've got.
Old Oct 1, 2015 | 02:41 PM
Over on this side of the pond you can buy things like that in any auto parts store.
Old Oct 1, 2015 | 02:58 PM
Yes last place I seen them was on one of those clip boards with hanging small items clear tray/boxes. Like myself 2 days ago in "The Range" store, but usually as said found in car accessory shops, Halfords even.
Old Oct 2, 2015 | 02:00 AM
tfb's Avatar
tfb
Old Oct 2, 2015 | 05:59 AM
Well of course tfb but splutter splutter...anyway their trim buttons and per my itsy picture you may recognise the see through box from Autobar stand.
Old Oct 6, 2015 | 06:20 PM
Maxcaddy's Avatar
Many thanks for your help and responses, but unless I have a different undertray and sides to everyone else they are not what I need.
On mine the undertray is held by seven 6mm bolts. Of these, at the front there are three 6mm bolts that screw into the metal underneath the front of the car. There are then two each side which screw into the side covers that stop the wheelarch spray going onto the ends of the engine, and these side covers each have two fixings for two 6mm bolts (each side) to go into.
These fixings (two on each side of the side covers) comprise of a captive nylon 6mm nut in a metal housing, which is held onto the side covers by two metal tags from the housing.
It is four of these fixings which I am after.
Old Oct 7, 2015 | 02:05 AM
tfb's Avatar
tfb
anything here
https://www.google.co.uk/search?q=ca...IVBLsUCh1IHQ8V
look like it?
it's too wet for me to crawl under ours to see what you mean
Regards
Richard
Old Oct 7, 2015 | 02:57 AM
Maxcaddy's Avatar
Yep, they're the little buggers, similar to the 5th along from the top row, and virtually exactly one of those at row 5, column 3.
Now.........without buying a minimum order quantity of 5000, does anyone know where they can be bought from (preferably because of postage) within the UK ?
Old Oct 7, 2015 | 06:45 AM
tfb's Avatar
tfb
