Vibration while idle
Old Feb 25, 2015 | 05:16 AM
discojohnno's Avatar
Default Vibration while idle
Hi Guys
I was just wondering if its normal for my Chrysler Grand Voyager 2.8L 55 plate limited XS to vibrate while idle i have only just noticed it and engine seems a little louder than normal
Regards
John
Old Feb 25, 2015 | 05:24 AM
Vmaxxer's Avatar
I had that too and imho its mostly due to 2 possible problems:
*Worn out engine mounts > replace engine rubbers
*Dirty injectors > let them clean professionally OR try the "Italian tune up method"
Italian tuneup - Wikipedia, the free encyclopedia
Old Feb 25, 2015 | 03:14 PM
Has your car lost any power and does it produce smoke from the exhaust under acceleration (injectors). When was the Cam Belt replaced (jumped a tooth).
Old Mar 1, 2015 | 02:44 PM
Any results Discojohnno to your problem.
Old Mar 2, 2015 | 01:29 PM
Sorry for the late reply, still not managed to sort the issue, still the same but there is no spoke coming out of the exhaust, however it does seem a little sluggish but not major, so need to try find the source of the issue, just seems like one issue after another now
also a little confused on the cambelt as i do not think it has been changed and also so many varying reports on when it needs to be change car has done 103k
Old Mar 2, 2015 | 02:18 PM
Check cambelt is not slack then...
Old May 31, 2023 | 02:34 PM
ChryslerKen's Avatar
Default Same problem
I have the same problem. Changed all engine mounts, only a short lived improvement. Did you find out wherher it was the cambelt or injectors?
70 roadrunner
Dec 3, 2014 07:48 AM
profyrfyter
Jul 13, 2013 01:30 PM
wtroger
Mar 7, 2013 02:59 PM
macfarlane300
Feb 2, 2009 09:00 AM
lancellot1
Sep 4, 2005 11:47 AM
