vibration while turning steering
Old Aug 8, 2005 | 03:52 PM
lancellot1's Avatar
Default vibration while turning steering
300 c AWD 11,000 miles. Just had tire rotation done, soon after, started noticing vibration while turning steering at parking lot speed. the vibration is there whether the car is is N or D, reverse or FWD. and it does it intermittently mostly in the mornings, or after the car has had a chance to cool. has anyone heard anything like this? please help!
Old Sep 4, 2005 | 11:47 AM
FlatEric's Avatar
Default RE: vibration while turning steering
Hello,
I joined just so I could input on this problem. I had the exact same thing in my Magnum RT AWD. There is a TSB out for the Magnum, but I just looked and did not find one for the 300. Dodge calls it "crowhopping" and it is a hard vibration making slow turns, especially at parking speeds, and it is only in the AWD. At first mine did it only in the morning, after driving 10 miles, it did not do it. It got worse and worse until it did it all the time.
My dealer replaced the transfer case and problem is gone. The TSB says the vent tube is misrouted, allowing water in. The new case has the vent tube in a protected place so water can no longer get in. Hope this helps.
Here are the details for the Magnum TSB:
2005 Dodge Magnum
Bulletin #: 04023
Sequence #: 10010565
Date: 10/08/2004
Component Name: 104000 power train:transfer case (4-wheel drive)
Make: Dodge
Model: Magnum
Year: 2005
Summary: Transfer case vent hose improperly routed which could result in water entering the transfer case and cause driveline shudder (crow hopping) during parking lot maneuvers. rapid response transmittal #04-023. *tt
discojohnno
May 31, 2023 02:34 PM
profyrfyter
Jul 13, 2013 01:30 PM
wtroger
Mar 7, 2013 02:59 PM
ietk
Feb 21, 2010 07:35 AM
KYBarrister
Oct 9, 2008 09:12 PM
