Voyager GS TD manual gearboxproblem and repair tools.
Old Oct 14, 2017 | 12:21 AM
SvenR's Avatar
Default Voyager GS TD manual gearboxproblem and repair tools.
Hello.
I changed gearbox but in new used box have problem. It whistle in 5th gear, when car moves down from some hill whistle stops. I think that problem is 5th gear bearing what is behind 5th gear, because it whistle only when throttle is on but when driving in idle all quiet. Does anybody had kind problem?
From that reasone I have another question. Does anyone say what size is nut before 5th gear, what size wrench I need? That 6252 tool I will build myself, because ordering time is around 2 weeks but I donīt have time.
Best Regards!
Sven from Estonia
Old Oct 17, 2017 | 02:14 PM
Add a bit more fluid to your box and see if it still whistles..Had a Renault Megane RX4 in past and it started to be noisy in 5th. Mind you all the Renaults went to their graves early due to this. It seems that the boxes were built with too much pre-load on the main input shaft and not having enough fluid in the box either made noise get worse of box go Bang. Shortest living car I ever did have, six years from new and it was scrapped.
TomC
63
Oct 6, 2023 06:04 AM
Ephata
Aug 5, 2014 01:01 PM
ancholme
Sep 11, 2012 03:05 AM
Carlo60
Apr 5, 2011 03:56 PM
