Voyager won't Start P1685
Old May 16, 2010 | 04:00 PM
romualdo's Avatar
Default Voyager won't Start P1685
Greetings from Portugal,
I own a Chysler Grand Voyager 2.5 CRD, and since yesterday it won't start.
I turned it off but didn't took the key out from the ignition, and when I wanted to start it again it didn't. Have done the procedure to read the error codes, and the code is P1685.
Is there anything I can do? Reset something? Or will it have to go to the dealer workshop?
Many thanks
Old May 16, 2010 | 04:05 PM
glowplug's Avatar
That code indicates that for some reason your SKIM module is not recongnising the chip in your key. If you have a spare key try that
Old May 17, 2010 | 06:11 PM
Merlin's Avatar
hi
I see this code all the time when there is no fault with the vehicle. I believe it can set with just leaving the ignition on. You will know if this is an active code and the little red LED on the dash will be on. If it goes out I would be looking at fuel issues not immobiliser issue.
But like glowplug suggested can't do any harm to try the other key.
Old May 18, 2010 | 05:39 AM
romualdo's Avatar
First of all, I would like to thank you for your replies.
I bought the car from a leasing company, and I'm still waiting for the second key.
The red light goes off and the behavior it's like I was not pressing the clutch pedal.
Old May 18, 2010 | 01:26 PM
Merlin's Avatar
so it's not even turning over? check the connection on the starter/ starter circuit. Not likely immobilizer fault.
Old May 20, 2010 | 06:24 AM
romualdo's Avatar
Great news!
Checked starter circuit as Merlin suggested and found the problem, it was the starter relay, after swap, it started at the 1st turn.
Many, many thanks!
estebanfree
Jun 5, 2014 01:40 AM
Mark Houghton
Apr 3, 2014 02:43 PM
Bee
Sep 15, 2013 01:49 PM
laura
Apr 11, 2010 08:48 PM
peter.g
Jan 22, 2010 04:45 PM
