Wiring diagram 2.5 td 1996
Hello to everyone,
I'm looking for engine wiring diagram with MAF sensor for 1996 Voyager 2.5 td.
All that I found in the google are with boost pressure sensor instead MAF.
I would be wondered if anybody will help me.
Thanks in advance.
Thanks in advance.
Never seen a voyager 2.5 TD with an air flow sensor MAF. But there is a boost sensor (MAP)with built in temp sensor so it can actualy calculate"estimate" the flow.
What is the problem , did the engine loss all power ?
Do you have a picture of this sensor install in the car ?
I do believe there is a component called MAP. It is the sensor assembly located just after the air filter that the intake air flows through.
Chrysler Town, Dodge Caravan. Manual - part 1178
The wiring should be in one of those pages I likned you to, but I have no idea which page.
A version of the Jeep 2.5L Diesel supplement is available here (no wiring diagram, though):
jeep-manual.ru/files/KJ/25CRD.pdf
The Jeep 2.5 is the same engine as the Voyager 2.5, and the 2.8 is identical in everything but the cylinder bore diamater (some minor adjustments may differ as well). Various components around the engine varies with model year. I had a 2.5 2003 Voyager where the EGR valve was rear of the engine, but on my 2.8 2007 it's in front of the engine.
/Fredrik
/Fredrik
WifesVan
Jan 20, 2007 01:11 AM
Jeremy2005
Sep 1, 2005 01:30 AM
