1995 cirrus drop transmission pan
Old Jun 8, 2011 | 07:15 PM
thm132's Avatar
Default 1995 cirrus drop transmission pan
Hi, I am doing maintenance on my 1995 Chrysler Cirrus LX with the 2.5L V6 and 4-speed automatic. I've done research, but found conflicting answers on how to seal the transmission pan for a drain and fill.
I ordered a Mopar transmission filter and RTV sealant from moparpartsamerica.com.
Instead of the sealant, will using a gasket like this seal better than the RTV?
Buy Felpro Automatic Transaxle Gasket TOS 18687 at Advance Auto Parts
I live in Lincoln, Nebraska, and this time of year the weather is hot and dry in the 90s.
How do I properly apply and cure the RTV on the pan?
What torque do the transmission pan bolts need to be set at? What size rachet needs to be used to take the bolts off?
Kudos to all who can help me!
Old Jun 8, 2011 | 07:53 PM
Djinn-n-Tonic's Avatar
Im not even going to look at the link......RTV works the best.....
1/8 inch bead around the perimeter of the pan, Just like decorating a CAKE....Dry any residual fluid from the pan rails, smoosh the pan up into place and hand tighten two opposing bolts.....
The rest are "SNUGGED" up with a 1/4 inch ratchet and all the muscle you can use with your fore and middle fingers only. I believe they are 10mm bolt heads
Chrysler Forum Editor
Dec 2, 2012 07:59 AM
ejayrandolph
Aug 21, 2009 10:28 PM
Termite
Apr 26, 2009 10:07 PM
MauriS69
Mar 17, 2009 10:31 PM
sebringted48
Jan 29, 2009 05:41 PM
