1998 Plymouth Breeze Cigarette Lighter and Horn not working
Old Feb 28, 2012 | 03:48 PM
makeamove's Avatar
Default 1998 Plymouth Breeze Cigarette Lighter and Horn not working
Hey guys,
Im having an issue here and trying to figure out why my horn and cigarette lighter isnt working and its been this way for the past 2 years. I have been looking for the cigarette lighter fuse but not luck with that. I checked on the side panel of the dash where the fuse box is and under the hood near the air filter and see nothing relating the cigarette lighter. As for the horn I checked the relay and when I put the relay in and press the horn all I hear are clicks coming from the relay but no sound from the horn itself. If anyone can guide me through this I would greatly appreciate it. I checked all over the web and not nowhere.
Old Feb 28, 2012 | 08:40 PM
MrNoizyToyz's Avatar
that relay that clicks did you change it
Old Feb 28, 2012 | 08:43 PM
is your radio working ?
Old Feb 28, 2012 | 10:12 PM
makeamove's Avatar
No I didn't change it and my radio is still working. Pretty much everything works except the Horn and Cigarette Lighter
Old Mar 1, 2012 | 08:54 AM
thats weird the lighter and radio work of the same power,my guess is the heating element is no good or unplugged form behind,the horn Do you hear a 'clicking sound' when you push the horn?
1st - make sure that your clockspring in the steering column. If so, the airbag warning light is usually on.
2nd- Listen for the relay (under the plastic box cover with the relays and fuses) in the engine compartment to click when you push the horn.
IF no click, try swapping the HORN relay with another identical relay (with the vehicle OFF). IF you get clicking and no horn, check horn connection and then replace the horn.
Old Sep 7, 2012 | 01:39 PM
97350's Avatar
My horn/cig lighter fuse blows occasionally as well.There is a 20amp fuse(#7 I think) that needs to be replaced.As far as the radio it is protected by a different fuse unless you have a factory high end stereo installed.I haven't found the culprit yet but will post when I do.
Old Jun 9, 2014 | 11:06 AM
RheaM's Avatar
Angry Hellllppph
I have a 98 plymouth breeze and my washer fluid and horn don't work I checked the fuse as they both run off the same one and it was blowin so I changed it but every time I try to put a new fuse in it blows as soon as it touches it help please why does it keep popping as soon as it's put in
Cmike
Apr 8, 2016 10:33 PM
vipergeis
Aug 20, 2013 10:58 AM
tkbelisle
Aug 17, 2012 05:13 AM
AZJOHN
Jun 30, 2010 12:46 PM
dski76
Aug 3, 2008 04:01 PM
