98 Cirrus 2.5 cranks but no start.
Old Nov 2, 2011 | 10:22 AM
crmzendrgone's Avatar
Old Nov 2, 2011 | 03:15 PM
that's not the C121 connector any way so plug that thing back in
the one U need is green and a 14 way connector
Old Nov 3, 2011 | 10:19 AM
So here is what I did.
I reconnected that plug. where is this green 14 way connector?
Old Nov 3, 2011 | 10:21 AM
Originally Posted by TNtech
Where is this 8 Pin connector you're talking about? Haynes manuals are kinda crappy. Do you have access to Alldata?
I do not have access to alldata, I wish. might be a future purchase though.
Old Nov 4, 2011 | 03:38 PM
  #15
Originally Posted by Someone on the internet
When you turn the key to the run position do the ASD and fuel pump relays click on and then off after one second? If not, is there power on fuses 8 and 10 at that time? If there is power to the fuses and the relays don't click then the PCM is not working properly. Check that there is power on plug pin 20 at the PCM dark blue/white at that time, and also verify that there is power on pin 46 at the PCM at all times (red/tan). Finally check that the wires on pin 10,47,50 of the pcm plugs show continuity to ground. If all that is correct then I would believe the PCM is bad.
Is this sound diagnostic advice or not really related to my issue
Old Nov 15, 2011 | 10:18 PM
  #16
Daughter decided to sell it, so vehicle was sold as is. good luck to the next guy.
Ebk4locster
Aug 7, 2015 08:07 PM
darlon
Apr 19, 2010 06:19 PM
size2020
Oct 17, 2009 08:21 PM
Greg
Jul 30, 2009 09:34 AM
jonboy_4x
Apr 6, 2008 12:19 AM
