cirrus 2.5 bogs when hot
Old Nov 16, 2007 | 03:34 PM
jaybrad's Avatar
Default cirrus 2.5 bogs when hot
Hello I have a 97 cirrus 2.5 that has a terrible hesitationwhen it gets warm. It gives me no codes and it has new: plugs, wires, fuel filter, cranksensor, tps, distributor, map sensor. I have the egr blocked off, it has good fuel pressure and volume, and it doesnt lose spark. After it gets warm if you snap the throttle, it bogs terribly. If you are driving it you have a hard time getting home. It has a perfect idle, will idle as long as you want. Any ideas?
Old Nov 17, 2007 | 02:41 PM
Default RE: cirrus 2.5 bogs when hot
clogged cat look at it see if it gets cherry red.
Old Nov 19, 2007 | 11:02 AM
jaybrad's Avatar
I forgot to put that in my entry one of the first things I tried was disconnecting the exhaust at the y. It acted the same.
Old Nov 20, 2007 | 08:22 AM
moe's Avatar
moe
how do you have the EGR valve blocked off ? pinched hose? they had big problems with egr valves on this engine.
Old Nov 20, 2007 | 09:51 AM
jaybrad's Avatar
The tube is removed, intake port blocked and vacuum line removed and plugged off.
DodgeInfoCenter
Jan 16, 2006 04:51 PM
qzking
Jul 30, 2005 04:49 AM
jdman1
Jul 22, 2005 05:08 PM
qzking
Jun 13, 2005 01:08 AM
May 19, 2005 10:16 PM
