cirrus 2.5 bogs when hot
Old 11-16-2007, 03:34 PM
jaybrad's Avatar
Default cirrus 2.5 bogs when hot
Hello I have a 97 cirrus 2.5 that has a terrible hesitationwhen it gets warm. It gives me no codes and it has new: plugs, wires, fuel filter, cranksensor, tps, distributor, map sensor. I have the egr blocked off, it has good fuel pressure and volume, and it doesnt lose spark. After it gets warm if you snap the throttle, it bogs terribly. If you are driving it you have a hard time getting home. It has a perfect idle, will idle as long as you want. Any ideas?
Old 11-17-2007, 02:41 PM
Default RE: cirrus 2.5 bogs when hot
clogged cat look at it see if it gets cherry red.
Old 11-19-2007, 11:02 AM
jaybrad's Avatar
I forgot to put that in my entry one of the first things I tried was disconnecting the exhaust at the y. It acted the same.
Old 11-20-2007, 08:22 AM
moe's Avatar
moe
moe is offline
how do you have the EGR valve blocked off ? pinched hose? they had big problems with egr valves on this engine.
Old 11-20-2007, 09:51 AM
jaybrad's Avatar
The tube is removed, intake port blocked and vacuum line removed and plugged off.
DodgeInfoCenter
01-16-2006 04:51 PM
qzking
07-30-2005 04:49 AM
jdman1
07-22-2005 05:08 PM
qzking
06-13-2005 01:08 AM
05-19-2005 10:16 PM
Quick Reply: cirrus 2.5 bogs when hot
