Heating
Old Dec 15, 2008 | 07:32 PM
planet_rob's Avatar
Default Heating
Hello all:
I have a heating problem with my '99 Cirrus,6 cylinder, 2.5L. When I come to a stop at a stop light, or any other stop that keeps me at idle for a minute or longer, the air coming out of my vents goes from nice and hot to cold. If I put her in neutral and rev...then it will get warm again. If I wait, then take off, ...warm again. I have plenty of coolant in the system.
Could the thermo be getting stuck closed?
Any help would be greatly appreciated.
Thanks in advance......................rob
Old Dec 15, 2008 | 08:50 PM
Default RE: Heating
low coolant then look for a leak.
Old Dec 21, 2008 | 07:16 PM
planet_rob's Avatar
Default RE: Heating
Hey Tech!
Thanks so much. I had said that I thought I had plenty of coolant, but I was going by the overflow tank. I took the cap off over at the engine, and it took almost the whole jug of coolant. I wonder why my overflow tank shows a couple of inches worth all the time?
I will look for the leak, and thanks again. After filling the system back up, heat works all the time.
Much appreciated.
.............rob
Old Jan 24, 2015 | 01:02 PM
Tom Gillis's Avatar
I have a 2000 Cirrus and the same problem, I checked the overflow tank and the area where the hose from engine enters the tank was never drilled out. I drilled and tapped and installed a brass fitting but I still have very little water going to my heater core. What next.
Old Jan 24, 2015 | 04:27 PM
Check the hoses going to the heater core to make sure they are not obstructed. Check the heater core itself to make sure it's not blocked. After 15 years, things can start to plug up.
If you decide to try to flush all or part of the system, do it carefully. The system was designed for about 15-16 psi of pressure. Household water pressure can be several times that and can blow seals and cause havoc.
mick1641
19
Sep 18, 2007 12:25 PM
needaauto
Feb 19, 2007 11:21 AM
jstwhi1
Jan 7, 2007 08:00 PM
davidandkeiley
May 12, 2006 03:36 PM
chicago_animal
Mar 28, 2006 11:38 AM
